rchibnik Posted April 1, 2018 Share Posted April 1, 2018 Just thought I'd recount my experience repairing my JTV89 which had an unreliable VDI connection pretty much since I got it. This guitar was an open box from Sweetwater so I saved a couple hundred bux on it. I was sure it wasn't the VDI cables since I also have a Standard and the cable works reliably with that guitar and the Helix. I figured the pins in the RJ45 jack in the guitar were bent - often I could get it to work by fiddling the VDI jack. Full Compass is a great source for parts for the JTV and line 6 stuff in general. I found a replacement input jack there - $52 seemed like a lot, but shipping was free. The 69 jack is slightly less expensive. Shipping was pretty quick and I had the new device in about a week. To replace the jack, I needed to open the back as well as remove the four screws securing the input jack. The Jack assembly has to connections, a six or so wire electronic PIN socket and a ground wire which screws to the guitars ground. No soldering is required. Disconnecting the PIN socket required a needle nose but came out pretty simply. The new one only goes in one way. I noticed that the old jack was not grounded- the green ground wire was not connected to the ground on the jack - it was loose connected to the guitar. This might explain the defect, but I'm not sure why it was intermittent. Rather than trying to re-attach the ground to the old input jack I went ahead with the replacement because I was unsure of any other issues, and i already had the replacement part. After the replacement, which took about 15 minutes, the guitar worked perfectly again. The component based design makes the JTV a very serviceable guitar. Of course, on a standard guitar, the wiring is far simpler and repair might be less expensive. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 2, 2018 Share Posted April 2, 2018 The other JTV's are it bit more work to get into. Quote Link to comment Share on other sites More sharing options...
