uslimey Posted April 2, 2018 Share Posted April 2, 2018 Finally installed gearbox on High Sierra... And it's working 100% Here's what I did. Download Gearbox 3.72 DMG Double click on the DMG package VIEW PACKAGE CONTENTS by: Right clicking on the Package Icon Left clicking 'View Package Contents' Double Click on Contents Double Click on Packages FOR EACH PACKAGE: Right Click the package and Select open. This will run the installer for the individual package Some packages may not install properly, but don't worry... NOW CHECK THAT EACH PACKAGE INSTALLED CORRECTLY For each Package: Right Click and view package contents (see above) Navigate to the folder /Content/Resources/english.lprog/ Double click on the file the ends with .info This should open as a text file. In the text file will be information about where the contents of the package were supposed to be installed. Make a note of the location Navigate to the folder /Content/Resources/ and double click on the .gz file Copy the extracted file Navigate to the target location you made a note of above If the file isn't there, paste it to that location Reboot the machine Open Monkey, and get and the latest driver. After you install the latest driver, make sure Monkey can see your POD. Open System Preferences: Under Security and Privacy General tab, if there is an exception for the line 6 package, click to allow it Make sure the Line 6 Audio Midi Tab is also there Now you should be good to go... The biggest problem I had initially was Gearbox saying that the driver for the X3 was incompatible or something like that... It turns out that the Gearbox uses 2 drivers... The first is the MIDI driver, which its happy to use the latest and greatest downloaded via Monkey. The second is the Audio Driver... The Audio driver was one of the things that didn't install properly when I installed each package... Someone else may want to make a more concise set of instructions... I spent a while messing with this... The really neat thing though are the .info files because they tell you what is supposed to be installed and where. Oh and if you can't see the Library folder(s) you may need to right click in finder and tell it to let you see it... Or you might have to do something at the Command Prompt... I am pretty sure I enables all of that on my MAC way back, and I can't remember exactly how you do it. 2 Quote Link to comment Share on other sites More sharing options...
Morketre Posted October 10, 2019 Share Posted October 10, 2019 Not work! Quote Link to comment Share on other sites More sharing options...
websters Posted February 29, 2020 Share Posted February 29, 2020 My system is Mojave and everything went well. One note is not to install the latest driver, make sure Monkey can see your POD. Install before doing this procedure and install the audio driver from the package. And remove the .X3m for the Gearbox to see the files. Quote Link to comment Share on other sites More sharing options...
rogeriosantosluz Posted May 7, 2020 Share Posted May 7, 2020 Unfortunately it didn't work. I'm finally retiring my TonePort KB37 purchased on 2007... Quote Link to comment Share on other sites More sharing options...
larskris Posted December 7, 2020 Share Posted December 7, 2020 Worked on Mojave 10.14.6 Thanks Quote Link to comment Share on other sites More sharing options...
neimusic Posted January 6, 2022 Share Posted January 6, 2022 someone managed to make it work on Bigsur? Quote Link to comment Share on other sites More sharing options...
Rollikerki Posted November 25, 2023 Share Posted November 25, 2023 Got it on High Sierra 10.13.6 Problem: I see only 2 Line IN or 2 Mic or 2 Instr. But Gear Box can see my UX8... How can I initiate the other channels, so I can use all 8 inputs? is it at all posible, to connect 8 Guitars to the UX8 or are there only inputs for Guitar? Quote Link to comment Share on other sites More sharing options...
