ckk0003 Posted April 21, 2018 Share Posted April 21, 2018 I have two amps. One has effects loop and one does not. How is the best way to create signal chain that will route the effects that I want to run through the loop. Any ideas. Quote Link to comment Share on other sites More sharing options...
tjbassoon Posted April 22, 2018 Share Posted April 22, 2018 I'd run the 4 cable method to the amp that can handle it ultimately out to the left channel and send the amp with no effects loop to the right channel, and create separate signal paths for both guitars when necessary. You may not end up using the HX Effects FX Loop very much with this setup, and probably run most of your effects just before the input of the amp, not worrying about the FX loops at all. Quote Link to comment Share on other sites More sharing options...
