giovi2008 Posted April 23, 2018 Share Posted April 23, 2018 I recently bought a Palmer battery pack and wanted to use it with the firehawk, so instead of wiring it to the default electricity using an adapter, I wanted to use the battery pack. The adapter the round exit easily went into the extension line of the batttery pack, but the different cords which serve as an output of the bat aren't pluggable to the firehawk, but they are pluggable to a pedal. I am nuisant what other users of a firehawk use as an alternative power source Quote Link to comment Share on other sites More sharing options...
robertgoddard Posted April 24, 2018 Share Posted April 24, 2018 If your battery pack has a 9V output with a negative (-) tip and positive (+) sleeve capable of 3A (3000mA) then it should work. I think the 3000mA may be overkill, I think it will work on 2A (2000mA). I had a hard time finding any battery packs that supply more than 2000mA, so you could always try. Quote Link to comment Share on other sites More sharing options...
