shanebrock1118 Posted May 20, 2018 Share Posted May 20, 2018 Hi i was wondering if there was a way to make logic control the helix through the USB when using backing tracks? Ive seen videos for how to do this with midi but not the USB i'm already using midi to control the channels on my amp the helix edit is able to do this with the USB so im sure there is way to make logic do it as well Quote Link to comment Share on other sites More sharing options...
funkyou86 Posted May 21, 2018 Share Posted May 21, 2018 6 hours ago, shanebrock1118 said: Hi i was wondering if there was a way to make logic control the helix through the USB when using backing tracks? Ive seen videos for how to do this with midi but not the USB i'm already using midi to control the channels on my amp the helix edit is able to do this with the USB so im sure there is way to make logic do it as well Logic can send program change messages. Here's an older video how to set it up. Quote Link to comment Share on other sites More sharing options...
soundog Posted May 22, 2018 Share Posted May 22, 2018 Set up a new External MIDI track, and use that for all commands you want to send to Helix. Use Audio MIDI setup to tweak your MIDI routing if needed. Then you can use an automation lane to control Helix in real-time, to tempo. Quote Link to comment Share on other sites More sharing options...
