mesatost Posted June 6, 2018 Share Posted June 6, 2018 Hi. I'm new to HX. I was hoping to be able to send one output mono to my electric amp, and one output to DI for acoustic, then assign appropriate effects/acoustic IRs to my DI. Hoping to have output to only one or the other at a time, dependent upon whether I'm playing acoustic or electric from song to song. Is this possible or do I still need an external A/B switch to toggle the output? Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 6, 2018 Share Posted June 6, 2018 It's possible, and it's very easy to set up. You could do it by hard panning the outputs for every preset, but I think you'd be much better off using one of the FX Sends as an output for your acoustic preset(s). I would just insert whatever Send block you want to use at the end of the signal path, and turn the Dry Thru parameter all the way down. That way you won't have any signal going to the 1/4" outs in the acoustic patches, but it will be coming out of the Send. Quote Link to comment Share on other sites More sharing options...
mesatost Posted June 7, 2018 Author Share Posted June 7, 2018 Thank you so much! I was just thinking of the same thing earlier today. I think using an FX send at the end of line will work very well. Quote Link to comment Share on other sites More sharing options...
