Sign in to follow this
Max604
Switching Between Sounds
Hello,
I've owned a Spider IV 75W for a long time and whenever I've needed to switch between a song preset (distortion) to a clean sound, I've always had to play with the preset knob to change my sound midway through a song. As you can obviously see, this is a time-consuming process and doesn't always work out perfectly so I've come here to ask for some for your help!
What is the best way and preferably the easiest way that I can transition between two defined preset sounds? I was thinking using a pedal, but would I need a special line 6 pedal or could I use something like my Boss FS-5U pedal to swap between two sounds.
I'm completely clueless how I would achieve this function with my Spider IV. Would I need to program something into my Spider to let the pedal function this way or something? Hopefully, you guys can help.
Thanks,
Max
You need an FBV MkII Express (or Shortboard) pedal to do this easily while playing.  Without a pedal, you save your 'clean sound' as a user preset, then switch to that preset using the front panel controls.  You should be saving your 'song preset' as a 'user preset', not just accessing them through the list of song/artist presets.
