frfr speakers
There are loads of options and numerous discussions, and everybody’s opinions are different depending on circumstances and expectations. Probably the best prosumer product (not cheap consumer and not professional price) is the Atomic CLR; a major factor for it is the coaxial speaker configuration which you don’t get in general PA speakers intended for longer distance listening. This can be important if using the speaker as a stage monitor as within 6’ is too close for the woofer and tweeter to merge for such speakers.
There are other coaxial speakers if you search but not many. One option that has to be recommended here if you want the speaker for use with Helix is the new Powercab which combines a guitar cab look with flat (guitar range) response and the option to simulate a range of guitar speakers. For Helix use unless you have PA requirements it should be tried before the L series PA speakers.
