PODXT live power supply
I think you will need a converter to change the input voltage from 220v to 120v.
The manual says "Connect only to AC power outlets rated 100-120v or 230v, 47-63 Hz (depending on the power range of the included power supply)." Your power supply says 120v AC.
Not sure what you're showing in the 3rd picture. You should check with Line6 Technical Support otherwise you could severely damage your PODXT.
