Graemey Posted July 14, 2018 Share Posted July 14, 2018 Ok, I had my first gig with the PC last night. Overall I found the PC slightly lacking in volume (we are not a super loud band, I'd say pretty medium) I have the input gain set so the LED just clips red when I turn on my Clean solo boost and hammer a clean power chord. So basically enough signal going into the PC I'd say. I had the volume up full but did not feel the sound was loud enough. I use a strat with vintage output pickups so I'm not driving the hell out off the input, but I'm sure Im sending enough signal in. My question is this: Is there a way to turn up the volume AFTER the input stage, for example a level control for each speaker model? I know the vol of IRs can be changed in the settings to compensate, but can I turn up the speaker models within the PC? My old on-stage solution was a single Line 6 L2T cab via Line 6 link and that had a LOT more volume. Quote Link to comment Share on other sites More sharing options...
Frankenkeim Posted July 16, 2018 Share Posted July 16, 2018 Did you try to adjust the output level directly? You can boost it up by +20db which adds significant volume if needed. If that's not enough, adding a gain block to your chain can add another +12db. Quote Link to comment Share on other sites More sharing options...
revans Posted July 16, 2018 Share Posted July 16, 2018 With speaker models, the only gain stage after the input stage is the (master) volume stage. Once the input LED is flashing and the volume knob is all the way up, there's nothing more. L2t: 800 W, 128 dB Powercab 112 Plus: 250 W, 125 dB A 3 dB increase is equal to a doubling of power. The specs say that an L2t should be about twice as loud as a Powercab 112 Plus. You should try running the output of the Powercab into the PA mixer and adding a bit of volume in the mains or in your monitor, depending on where you want more volume. I have my Powercab facing me (tilted back and pointed at the side of my head) and facing away from the rest of the band and away from the audience. The PA monitors and mains give the rest of the band and the audience whatever volume they each need. 2 Quote Link to comment Share on other sites More sharing options...
Frankenkeim Posted July 16, 2018 Share Posted July 16, 2018 Correct - I meant boost the output level in your patch (likely the Multi Output setting in your patch). Doing this works great for me and adds plenty of volume (same for adding a gain block in the patch if needed). Hope that helps - if not I have no other ideas either. 1 Quote Link to comment Share on other sites More sharing options...
Graemey Posted July 16, 2018 Author Share Posted July 16, 2018 Thanks guys, very helpful advice. I found getting the PC up to head height helps with volume but I'm not convinced it's right for me yet. I will keep using and see if I can make the PC work with my band. I can get some more stage level through my personal (vocal) monitor, but hey, I just hoped the PC had been designed to deliver more output volume for gigging situations. Quote Link to comment Share on other sites More sharing options...
Graemey Posted July 17, 2018 Author Share Posted July 17, 2018 With regard to squeezing more volume after the input stage. Here's a screen shot from the edit software. Speaker level at minus -14 so I can adjust for more volume I guess? Quote Link to comment Share on other sites More sharing options...
Frankenkeim Posted July 17, 2018 Share Posted July 17, 2018 Only if you route it directly to your front of the house guy I think. If you only have the amp on stage I do not believe you will hear a difference. Jason made a very good video about it. Check it out: Quote Link to comment Share on other sites More sharing options...
