bangbig Posted August 20, 2018 Share Posted August 20, 2018 All was good then I decided to update to 2.6 from last version. All went well, adjusted verbs as needed via the Helix floor unit. The next day went to use editor and the IR column shows all as empty, although the floor unit still has all of them as it should. Editor will import from laptop, but will not highlight or load them. Any ideas???? I tried to back up the ir's from a date before the update, says it's successful, but no dice still an empty list. Quote Link to comment Share on other sites More sharing options...
bangbig Posted August 20, 2018 Author Share Posted August 20, 2018 Re-install did the trick! Quote Link to comment Share on other sites More sharing options...
VirtualGuitars Posted August 21, 2018 Share Posted August 21, 2018 20 hours ago, bangbig said: Re-install did the trick! No different than PCs. Reboots/reloads usually fix most of the common problems. Quote Link to comment Share on other sites More sharing options...
