4 Cable Method in HX Effects issue
JakeMann35
Hi All
I wonder if anyone can help. Previously I have been playing in stereo using a Lehle Little Dual to take care of stereo effects between amps.
I’m now in the process of using the HX Effects as my main hub for effects. Using the 4 cable method I am able to route my delays and reverbs etc to the effects loop of one amp. But I’d like to still run stereo effects in the front of both amps.
Any idea how this could be routed/wires up?
thanks
Here is my setup using two Marshall Silver Jubilee's with the 7CM.  Path 1 is setup for FX Loop 1 and Path 2 is setup for FX Loop 2.  If you want to run your effects in stereo, make your Path 1 output PAN LEFT and your Path 2 output PAN RIGHT.  This setup works great for me.  Just remember that any effects before the FX Loops will be processed in mono regardless if you choose stereo effects or not.  No sense wasting the DSP processing power for non-time based effects.  I also assign a stomp button for each effect in both paths.  In other words, If I select my Delay, it will enable/disable that effect in both paths simultaneously.  This should work the same on both the Helix and the HX Effects.  Hope this helps you.
4 Cable Method (4CM)
Cable #1 Guitar to Helix/HX Effects Guitar In
Cable #2 Helix/HX Effects FX Send Loop 1 to Amp #1 Main Input
Cable #3 Amp #1 FX Send Loop to Helix/HX Effects FX Return Loop 1
Cable #4 Helix/HX Effects 1/4" Left (mono) Out to Amp #1 FX Return Loop
7 Cable Method (7CM)
Cable #5 Helix/HX Effects FX Send Loop 2 to Amp #2 Main Input
Cable #6 Amp #2 FX Send Loop to Helix/HX Effects FX Return Loop 2
Cable #7 Helix/HX Effects 1/4" Right Out to Amp #2 FX Return Loop
