Helix Expression pedal stuck on EXP 2
threetle
5 hours ago, threetle said:
I am not sure if I am doing something wrong. The built in Helix expression pedal is set to EXP2 . How do I get it back to EXP 1? I assumed there was some kind of switch inside but nothing is clicking. Any help would be appreciated.
Page 6 Helix owners manual:
16. Expression Pedal
Move the expression pedal to control volume, wah, or a combination of amp and/or effects parameters. Activate the hidden toe switch to toggle between EXP 1 and EXP 2. (The scribble strip above tells you which one is active.) If an external pedal is connected to the rear panel EXP 2 jack, the built-in pedal becomes EXP 1 only.
What they don’t tell you how difficult it is to get the switch to engage. You need to have the Helix on the floor a press down on the toe end of the pedal. Some users have found that using the supplied hex key tool, loosening the pedal a little may help.
Note: If you have a volume or pan block in your preset it will be auto assigned to EXP2, likewise if you add a wah or pitch shift pedal, that will be on EXP1.
Hope this helps.
