Problems with patch download
RQuesenberry
1 hour ago, RQuesenberry said:
Hello All, I am having a problem with downloaded patches working properly on my Helix unit. They show up in the home screen with blocks and  so forth but not on the scribble script or the foot switches. any thoughts on what the issue may be?
Hi RQuesenberry,
Best guess is that the blocks have not been allocated to any of the foot-switches.
To assign an effect block to a foot switch, use the joystick too navigate to the block you require, which will highlight with a white box. Lightly touch, for a few moments, the the footswitch that you wish to assign as the on/off for the effect. Simply press the button (at the bottom of the main screen) below the green box marked with a tick. Repeat for other block as necessary.
Hope this makes sense.
