audiotechnician Posted November 3, 2013 Share Posted November 3, 2013 Changed from 11's to 9's but even with the bottom E saddle and the bridge adjusted fully back did not have enough string length to intonate the bass strings so had to find a longer bolt to replace the inadequate length hex grub screw fitted. Anyone else had this problem? Quote Link to comment Share on other sites More sharing options...
nikoniablue Posted November 3, 2013 Share Posted November 3, 2013 I think I would do if I changed to 9's. My bottom E saddle is about as far back as it will go and it doesn't have enough play to allow for lighter strings. I've thought about changing to 9's - having received some free with a cable - but have held off for this reason. Quote Link to comment Share on other sites More sharing options...
audiotechnician Posted November 7, 2013 Author Share Posted November 7, 2013 Having played for nearly 50 years now even 9's feel like telegraph wires now with my dodgy finger joints and you sacrifice the sound and volume that 10's or 11's give you but fret wear may be less if you're a lead player and bend strings a lot. I don't know what thread the bridge string length adjustment screw is but it needs to be 1/2" long for intonating 9's, (the end of my original adjustment screw was burred through post adjustment so screw it right through to remove it as unscrewing it could damage the bridge thread), doesn't look great either as the upper support post is protruding out of the bridge and you can't access the height adjustment. Quote Link to comment Share on other sites More sharing options...
pugdealer Posted November 30, 2013 Share Posted November 30, 2013 I play 11's and I had to extend the bridge scews to pull it further back to get a good intonation...it event got the connector underneath the bridge rubbing the wood...it's as far back as it can be! I use earnie ball power slinky 0.11s That's the only way I can get it to intonate correctly! Quote Link to comment Share on other sites More sharing options...
