pott24 Posted October 8, 2018 Share Posted October 8, 2018 I just ordered an HX Stomp, and even though I have 0 experience with the Helix (I'm an AX8 user), I was thinking of using a spare Boss FS6 I have to get 5 footswitches rather than 3 (I think the math adds-up there...). I know the unit isn't out yet :) And I DID read the manual, but I'm a little confused about it. For example, it mentions the footswitches can only be used to switch between a Min/Max value of a given parameter? Hence I am assuming the way this works is similar to existing Helix units. If I'm wrong, may Zeus strike me down right now. What I'm trying to achieve is: * Unit's footwitches for 3 channels, i.e. any 3 preset per bank (1+2 and 2+3 together to change banks) * Keep footswitch 3 on the unit for the tuner, when using a long press * FS6 toggles 2 effects on/off for each preset (typically, mod + OD) This brings the Stomp to how I setup the AX8, with a much simpler and smaller setup overall. I don't ever use many more sounds, and if I do they can be on at all times (e.g. Reverb, Comp). Will this, or a similar variant, be a possibility? Cheers for indulging my impatience! :D Quote Link to comment Share on other sites More sharing options...
njglover Posted October 8, 2018 Share Posted October 8, 2018 I don't have the Stomp, so I can't speak to that specifically, but I don't see why you shouldn't be able to assign the bypass to the external switches. After all, bypass state is technically just reading a min/max state of the bypass parameter. Quote Link to comment Share on other sites More sharing options...
pott24 Posted October 12, 2018 Author Share Posted October 12, 2018 Thanks! And I can confirm, it works just fine. I can use these buttons for any of the options available under Global Settings. Weird thing is: * I can't reassign FS1/FS2, those are always doing whatever the Play mode is * I can't assign the Tuner to any other buttons' long press; it's stuck forever with the Tap tempo and hence takes up another extra switch The last part is particularly jarring: with so little footswitches given the complexity of the unit, why sacrifice one for Tap tempo as condition to get the tuner? Not everyone uses that function while a tuner is much more universal (albeit many players have external units; but making the unit's tuner available on any switch's long press negates the need for an external tuner). 1 Quote Link to comment Share on other sites More sharing options...
