HX with EX1 Volume Pedal Glitch
pjmelton11
Hello,
I hope I am posting this in the right area. I am experiencing a weird glitch and was hoping you guys could help me out. When using the EX1 with my HX Effects on the Volume Pedal patch the volume completely cuts out in the middle of the pedal's range and then kicks back in. It doesn't matter which direction you move the pedal in. Swells and fades cause the volume to skip and stutter. I thought it was just a bad pot but the pedal is working fine and smoothly on the wah patch. I even tried it with a keyboard that allowed expression pedals to control pitch bend and it worked smoothly there. I think it's something with the volume pedal patch. Any tips to get this working smoothly?
Cheers,
Peter
What expression pedal are you using? If you're using it with a keyboard, it sounds like you're using a TRS pedal. Line 6 expression pedals are wired differently than standard pedals and use a TS connection.
