Swirlygiver
Battery replacement
Has anyone replaced their battery and added a battery clip, so that they don’t have to remove the board and solder?  If so, where did u get the clip, and did u also change the battery type?
Yes i have replaced it with a batteryclip and solder on the board, type of battery = GP Lithium CR2430 and delivered by conrad.nl (German electronicsshop).
The results after replacing perfect.
Yes on the same place, i have not testing the change with the new replacement. The best is before you change the battery to make a back-up from you amp/tonebanks (i think so, but.........)
Did the battery clip have 3 pins?  I don’t suppose u could send me a link to one?  And did u take a photo of it afterwards?
Yes en maybe you must solder a extra wire to one of the pins (i could not find a 3 pin holder)
Wow. Thanks for the photo. Thats a tight squeeze.  Looks like the battery comes out towards the heat sink.   Did u solder it yourself?
Batteryclip laying under de cooler, this is a cooler for a another compenent. Yes i solder it. Before you do that, code the cables and take photo's because a lot of things must be reconnected.
