fredner Posted May 10, 2013 Share Posted May 10, 2013 helloI had a problem with my relay 30 is my last concertall the lamp receiver are turned red and I had an ultrasound as ringing in my ampvenai that the relay because when I put a cable problem morethe problem came after 2 hours of play and I did this before I had amais with relaysomeone has already had this problem can t help it because I'm afraid for my next concertthank youfred Quote Link to comment Share on other sites More sharing options...
dboomer Posted May 10, 2013 Share Posted May 10, 2013 Knowing only this small amount of information I can only make a few guesses. The fact that the RF LEDs when to red means that the receiver lost the signal. This could be from range limits, loss of line-of-sight or local interference. It could also happen if the transmitter is having hardware problems. I would need to know which mode you are operating in? Are you using the factory power supply? Are there any other Line 6 wireless devices used in the same venue? Quote Link to comment Share on other sites More sharing options...
