HX Effects Expression Pedal Glitch
Yuhyeon320
Hi
I'm using HX effects for almost 2 months
It worked fine but recently I had a problem with expression pedal.
When I connect my expression pedal with my keyboard, as you see, it works fine
But when I connect it with HX Effects,
For few minutes, it works fine. But soon later, it works like this.
0%(heel position) = 0
10% = 10
20% = 0
30% = 30
40% = 40
50% = 50
60% = 60
70% = 70
80% = 80
90% = 80
100%(toe position) = 80
Can someone please give me some advice on how to fix this problem
My expression pedal is Nektar NX-P
P.S Sorry for my bad English and thank you for reading my post
Helix products are finicky with expression pedals.
The one you list has a TRS plug, the Helix line wants a TS plug... that doesn't mean you can't get it to work, but it's not a good start to compatibility.
When I look at the product, it looks like it could be a cousin to the M-Audio EX-P.  It's easy to get those to work, but I don't want to steer you down the wrong path if it's not the same.
  • Thanks 1
  • 3 years later...
