NebWeb Posted December 2, 2018 Share Posted December 2, 2018 The previous owner of my XT Live replaced the original pack with a monsterous industrial multi-voltage adaptor, which is huge and heavy. I was thinking about getting this one 9V Charger Replacement Pedal Line 6 POD XT Live. Does that look like an AC/AC adaptor to you? It promises to be a bit too small and thin (110g 8x5x3cm) in my opinion. That's what I'd expect from a DC adaptor, and it doesn't seem to have the the 'boxy' shape of an AC adaptor. I'm worried that I'll either not get the AC charger pictured and end up with another huge one, or that I will get the charger pictured, but it won't be AC/AC. I'm trying to contact the seller, but it seems you can only do that through the stupid 'ask the community' feature, and very few sellers seem to reply to that. Opinions, please. Quote Link to comment Share on other sites More sharing options...
cbrillow Posted December 3, 2018 Share Posted December 3, 2018 The page you referenced is somewhat misleading. The main picture that first came up is of a 9V DC supply that is of a different physical size, configuration and voltage type than the XT Live requires. There is a picture and a link to another power supply under the line that reads: "Los clientes que vieron este producto también vieron" That supply outputs 9V AC, which is what the XT Live requires as its input power. Quote Link to comment Share on other sites More sharing options...
daveny5 Posted December 3, 2018 Share Posted December 3, 2018 I recommend ordering a new power supply from Line 6, if one is available. DC supplies not only have to have the correct voltage, but also the correct polarity. If it's not, you can damage your unit. Quote Link to comment Share on other sites More sharing options...
cbrillow Posted December 4, 2018 Share Posted December 4, 2018 11 hours ago, daveny5 said: DC supplies not only have to have the correct voltage, but also the correct polarity. If it's not, you can damage your unit. Very true. However, the required supply in this case produces AC volts, not DC. Quote Link to comment Share on other sites More sharing options...
NebWeb Posted December 4, 2018 Author Share Posted December 4, 2018 Thanks for your replies. Yep - the one pictured in my link is very likely to be a AC/DC adaptor. Following your advice, I'm going to go try to go through the Line6 distributors, to see if they can locate an official replacement. http://l6locator.yamaha-europe.com/?country=ES#tab=tab-1 Quote Link to comment Share on other sites More sharing options...
