IRs for HX Stomp via HX Edit..in list by won't go into block????
mctimney
I can import IRs into HX Edit...and they show up on the Impulses' list on the left side of the screen when I go to the tab, but they do NOT show up in the main EDIT screen (next to Cab, Volume/Pan/etc.) under 'Impulse Response.'  (See attached image.)   I can't drag the imported IRs into a block either.  Nor can I figure out how to get them in the edit list where I can select them.  I can add the two IRs that came with HX Edit no problem.... but these ones...????
I do have the latest firmware for HX Stomp (2.71) and the most current HX Edit software.     I downloaded these IRs for free...so maybe there's the problem?  I've attached one of the IRs for someone to check out if they'd like to help.
Related note: I'm really only interested in an IR for an acoustic guitar.  I've heard the 3 Sigmas are probably the best. I'm using a Taylor T5, which isn't a true acoustic, and am wondering what IR might work best.  Thanks in advance!
T814NeuKM84.wav
You select whether you want to use a 1024 or 2048 sample IR from that screen by clicking on one or the other. Then in the edit portion of the screen, just click on the IR block. There you'll be able to select what IR file you want to use by using the first parameter slider.
