IBbrianB
Mono/Stereo Output ???
If I run the Helix and all patches in mono only, are the Left and Right XLR outputs exact mono duplicates?
In context - I would like to run Left XLR out to the FOH PA, and also run the Right XLR out to a powered FRFR speaker. Are the L and R outputs the same?
Yes they’ll be the same.
note that you only need a mono block at the end of the chain to make it mono. Some effects, like post-amp reverbs and delays, can sound better / fuller with their stereo versions.  You can collapse them to mono by putting a mono block at the end of the chain.  A volume pedal set to 0 gain would do the job.
