bdpalmbos Posted November 12, 2013 Share Posted November 12, 2013 Hello All, This past spring I purchased a used Epi Les Paul Custom that came with a POD XT Live. It took me a while to figure out how to use the POD and adjust the tones to what I wanted. But, after getting used to the POD and figuring it out I really like it. Last week while practicing I was having some sound issues. I would select the channel that I wanted and start playing and the sound would drop out. If I hit the same channel on the POD it would reset itself and I would have regular volume again for a few seconds and then it would drop out again. I switched guitars to make sure that the guitar was not the cause of the problem. Another issue that just started is a worbling sound when I am using any distortion. This past Sunday while playing at Church I was playing very soft at the end of the service and all of a sudden the volume just spiked out of nowhere........NOT COOL!!! Any suggestions???? When practicing at home I am going through a DI box, and then directly into the powered mixer, at Church I play into an amp that is mic'ed up. Thanks! Quote Link to comment Share on other sites More sharing options...
dbaudrate Posted November 19, 2013 Share Posted November 19, 2013 Wow, I'll bet the congregation thought the Spirit had really come down when that volume kicked in! :D The first think I do when I have weird issues with my XTL is reflash the memory. Seems to work for me. have you connected the board to your computer before? Quote Link to comment Share on other sites More sharing options...
bdpalmbos Posted November 21, 2013 Author Share Posted November 21, 2013 Yes, I have plugged in my POD to my computer to create tones.....but have never messed with anything to do with the memory. Quote Link to comment Share on other sites More sharing options...
dbaudrate Posted November 22, 2013 Share Posted November 22, 2013 Make sure you've saved off the contents of your POD as a bundle, or just the individual patches that you've created before you reflash the firmware Quote Link to comment Share on other sites More sharing options...
