bonfnjovi69
Spider jam powers off and on
My spider jam powers off and on continuously when I turn it on anyone know whats the problem , did factory  reset and same thing ,  re- updated firmware still no change any help would be great or a fix to stop it.
Register your product then log a support ticket, and they will inform you of your options.
This one is not a self repair fixable problem. A Line 6 authorized service tech will have to
get inside this one.
  There's a computer chip on the circuit board which houses the SD Card that cuts off when it over heats. (I call it overclocking.)
  It's a defective chip where it has to be replaced.
  Since My Spider Jams Warranty Expired, I had to purchase a replacement circuit-board and add a cooling fan to it.
  Solved my problem!
  Neil
Good guess though, not bad. Original post is a different problem for power
cycling like that.
It's something that will have to be service at an authorized service center.
Not a generic part you can get at the corner shop.
neilzhere thanks, I turn it on it would stay on four second and then restart over and over,it was the chip used thermal past and pre 80's copper pennies as a heat sink played four 6 hours and left it on for 12 never shut off once ...THANK YOU!
HI, Dude,  Did you get this fixed?  If so what was it?  mine is doing the same thing.  They want more than the thing is worth to fix it and won't give me any schematic or sell me a tech manual.
I already replaced the amp just want to avoid the land fill.  it's an easy bolt on fix.
Thanks for any help you can give me.
Hi  Technicians. My Amp does the same. Switches off after a few minutes. Can anybody help me please with good ideas ? Thank You
Line 6 authorized service in your area. Not a user repairable issue.
For such an old Amp it is not worth doing a professional Repair.
I am Technician in Electronics and if i have had the right Information i will do the change of circuits by myself.
Last possibility is to exchange the whole PCB.
https://www.fullcompass.com/prod/218711-line-6-50-02-0186-main-pcb-for-spider-jam
If anyone can (want to) help me i will say thank You very much
More than likely not just the main processor board. Private Message me with the serial#.
