chrismkane Posted December 30, 2018 Share Posted December 30, 2018 Hello, I am currently changing my Amp channels (Bias Amp Head) with the MeloAudio Midi Commander. When switching channels, it also switches presets on my HX Effects. I have 9+ Effects in each amps signal chain. I am setup with the MA Midi Commander for the bottom 4 switches to change the amp channels and then the top 4 are free to use as CC commands or also preset changes. I’m having trouble figuring out how to utilize the top 4 switches for extra effects with CC commands... Im not sure if I can set a CC command to the HX to add any Effect that I program it to change with the Midi Commander? Is there a CC list for all the effects or can I only turn blocks on and off within the signal chain on the HX? If I can only change blocks off or on within the signal chain, where can I find the appropriate CC number? Thank you for any help and/or advice. Chris Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 30, 2018 Share Posted December 30, 2018 See page 43 of the manual. Quote Link to comment Share on other sites More sharing options...
