Helix Rack Midi
Jasonzebra3
Just changed my effect set up to the Helix Rack. Controller is the Mastermind GT16.
Anyone using an Rjm controller and know how to Midi control the Helix. Is it 1 or 2 midi 5-pin cable set up?
Do I need bidirectional control like the Axe Fx?
My first user preset is CC32 002
PC 000
CC69 000
I assume I have to change the on/off settings from the standard 0-off and 127 on to the snapshot value numbers.
Would I programme the three actions below to achieve user bank, preset & snapshot.
CC32 02-on number for user bank.
PC 0
CC69 0-on number for 1st snapshot.
What off number or none? As 0 will surely conflict with the 0 on value numbers.
Thanks
Jason.
On the Helix assuming that the Rack interface is like the floor:
Use the preset knob to select the Setlist, Preset and snapshot that you want to call
Over the second knob you'll see the exact midi messages you need to send
Setlist 2, preset 003 (1D), snapshot 4 = CC#32 value 001; PC#003; CC#69 value 003
You'd send the CC#s using regular (NOT TOGGLING) CCs.
You use the 5 pin midi cable from the MM16 OUT to HX Rack IN
Connect the USB to your computer to use the editor SW.
