bluerubin Posted January 8, 2019 Share Posted January 8, 2019 I am still using my Flextone II. It is a good amp. I just can no longer use Line6 Edit. I know this is an old amp, but does that mean I should throw it out and get a new SpiderIII? Tried one of them, nope. Believe me I know that I will get zero support from Line 6, I just wanted to see if there are any others out there with same problem, Java does not work with Line 6 Edit. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted January 11, 2019 Share Posted January 11, 2019 On 1/8/2019 at 1:58 AM, bluerubin said: I am still using my Flextone II. It is a good amp. I just can no longer use Line6 Edit. I know this is an old amp, but does that mean I should throw it out and get a new SpiderIII? Tried one of them, nope. Believe me I know that I will get zero support from Line 6, I just wanted to see if there are any others out there with same problem, Java does not work with Line 6 Edit. Like it or not, today's tech is disposable... particularly anything that relies on computer connectivity for certain functions. Sooner or later we're all forced to upgrade to the "next big thing" if you want stuff to work right. And honestly, even if you liked it, the Spider III you mentioned wouldn't be much of an "upgrade"... at this point, that one's old too. Quote Link to comment Share on other sites More sharing options...
bluerubin Posted December 15, 2020 Author Share Posted December 15, 2020 I was looking at my old post; found the work-around back then. I had to delete the current "Java" and load an old version. Now I am trying to figure out how to connect my Gear Box silver plug-in to be recognized. Monkey is not doing any update for me. I will look in the archives for a "work-around." jre-1_5_0_11-windows-i586-p-iftw.exe Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted December 15, 2020 Share Posted December 15, 2020 2 hours ago, bluerubin said: I was looking at my old post; found the work-around back then. I had to delete the current "Java" and load an old version. Now I am trying to figure out how to connect my Gear Box silver plug-in to be recognized. Monkey is not doing any update for me. I will look in the archives for a "work-around." jre-1_5_0_11-windows-i586-p-iftw.exe 245.76 kB · 0 downloads It's your time, so do as you like... but given that this thread is nearly 2 years old, by the time you get this all sorted out (which remains an "if") you'll be gumming down pudding in the old folk's home...;) You might want to start thinking about an upgrade because I honestly think you hit the point of diminishing returns some time ago...don't be your own speed bump. The current generation of modelers are stealth fighters, and you're piloting a biplane... nothing lasts forever. Quote Link to comment Share on other sites More sharing options...
