alessiohelix Posted January 9, 2019 Share Posted January 9, 2019 Hi, new owner of a helx lt here. I use it only on headphones and i want to use one amp with two cabs panned stereo and then adjust them to taste left and right. Can you tell me step bu step how to make it? thank you Quote Link to comment Share on other sites More sharing options...
j_hotch Posted January 9, 2019 Share Posted January 9, 2019 Quote Link to comment Share on other sites More sharing options...
alessiohelix Posted January 9, 2019 Author Share Posted January 9, 2019 thanks but i want to do it with one amp Quote Link to comment Share on other sites More sharing options...
j_hotch Posted January 9, 2019 Share Posted January 9, 2019 Ok, then you would place the split after your amp and direct each branch to a cab model: If you want to build everything on the same path, you can: Select one of your two cab blocks, press ACTION, and use the joystick to move it down.This creates Split and Merge blocks. If necessary, move your Cab, Split, and Merge blocks accordingly. The Split should be to the left of the first Cab and the Merge should be to the right of both Cabs. Select the Merge block and set its A Pan parameter to Left 100 and its B Pan parameter to Right 100. Good luck! Quote Link to comment Share on other sites More sharing options...
