dlettau Posted November 20, 2013 Share Posted November 20, 2013 I have a pod hd desktop. I just purchased a L3T and am getting it tomorrow. What is the best way to connect the two? What kind of cable should I be using between the pod and the l3t? Thanks. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 20, 2013 Share Posted November 20, 2013 I would connect the HD 1/4" outputs to the Line In inputs on the rear panel of the L3t. Set the POD HD output mode to studio/direct, and the switch to Line. Set the L3t to Reference mode. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 20, 2013 Author Share Posted November 20, 2013 What type of cable would I use? Would I use a speaker cabinet cable? Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 20, 2013 Share Posted November 20, 2013 Yes. Any audio cable will do. Generally speaking, avoid the really cheap ones. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 20, 2013 Author Share Posted November 20, 2013 I will probably use Mogami Cables. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 21, 2013 Author Share Posted November 21, 2013 Ok. Got my L3T today. Hooked my phone up to it and played some music through it. This thing cranks! Got it home and plugged my Pod HD Desktop into it. I plugged into the back panel and set the speaker mode to electric guitar. Not overly impressed so far. Sounds a bit muddy. I plugged a Monster instrument cable into the pod hd left out into the line input next to the auxiliary composite l/r where I plugged my phone into. Hopefully I have it hooked up wrong. Any suggestions would be great. Tried to call Line 6 tech support but they were all in a meeting until closing time. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2013 Share Posted November 21, 2013 I would connect the HD 1/4" outputs to the Line In inputs on the rear panel of the L3t. Set the POD HD output mode to studio/direct, and the switch to Line. Set the L3t to Reference mode. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 21, 2013 Author Share Posted November 21, 2013 Ok. Found the studio/direct. It was already set to that. Not sure how to switch pod to Line. When you say connect pod outputs to rear panel, as I see it the rear panel only has a single input. The side panel where the eq and effects are there are 2 inputs. Which should I be connecting to? Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2013 Share Posted November 21, 2013 The HD500 has a physical switch labeled Line/Amp on either the back or top of the device. Set the switch to Line. Use the Stereo RCA inputs on the rear panel of the L3t. This will require you to use adapters on your audio cables, or get a pair that have different ends. The HD500 end is 1/4" and the L3t end is RCA. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 21, 2013 Author Share Posted November 21, 2013 I have a HD Desktop. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 21, 2013 Author Share Posted November 21, 2013 You don't connect the 1/4" from the pod to the 1/4"of the L3T? Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 21, 2013 Author Share Posted November 21, 2013 Responded to my own post. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2013 Share Posted November 21, 2013 The Pod HD 1/4" outputs are a stereo pair. If you connect only one of the pair to the L3t 1/4" input then your L3t is receiving half the stereo signal. Use both 1/4" outputs from the HD, and connect them to the L3t RCA stereo inputs. That way your L3t will receive the full signal, even though you will hear it in mono because there is only one L3t. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2013 Share Posted November 21, 2013 The Pod HD outputs are Line level; no need to worry about a Line/Amp switch. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 21, 2013 Author Share Posted November 21, 2013 Ok. So I will need a 1/4" to RCA composite cable. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2013 Share Posted November 21, 2013 Yes - in stereo; a pair of them. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 21, 2013 Author Share Posted November 21, 2013 Do recommend any particular brand? Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2013 Share Posted November 21, 2013 No. But you don't need expensive stuff - middle of the road will do fine. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 21, 2013 Author Share Posted November 21, 2013 Just seems like you would loose quality going from the 1/4" to rca? Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2013 Share Posted November 21, 2013 Why? Try it. Quote Link to comment Share on other sites More sharing options...
dlettau Posted November 21, 2013 Author Share Posted November 21, 2013 Thanks I will. I also read that you can use the mixer to pan everything to the left. Quote Link to comment Share on other sites More sharing options...
