bull1030 Posted November 20, 2013 Share Posted November 20, 2013 I got the Ex1 pedal and connect to pedal 2 input. The hd500 flips and recognizes the onboard pedal as 2 and the extra pedal and number 1. Is it something i can correct or is it slightly retarded? Quote Link to comment Share on other sites More sharing options...
smrybacki Posted November 20, 2013 Share Posted November 20, 2013 Only 95% sure (not at home right now), but I think that my EX1 which I just got is set as EXP2. I have no idea how or why our two units are different, but they seem to be. Once you get it working, I'm sure you're gonna love it though.From the manual:Expression Pedal & Variax® Knob Controller AssignmentPOD HD500 includes two Pedal Modes, EXP 1 and EXP 2 for the “on-board†Pedal, each of which can be assigned to any FX Model or FX Loop parameter, for endless control possibilities.* Or, when an Expression Pedal is connected to the PEDAL 2 input on the back of POD HD500, the on-board Pedal controls EXP 1 and Pedal 2 controls EXP 2. The EXP 1 and EXP 2 Pedal Modes can each be assigned to control independent FX parameters. These EXP 1 & EXP 2 assignments and all settings made here are saved per Preset.*Note that when you add a Wah FX Model to your tone, the “Position†parameter for the Wah is automatically assigned to EXP 1. Likewise, when adding a Volume or Pan FX Model, its Position parameter is automatically assigned to EXP 2. This will result in multiple items assigned to these EXP Pedals if you already have existing Pedal assignments. For all Factory Presets that already include a Wah, Volume or Pan, these are typically already assigned as well. You can change these Pedal assignments, and/or create your own for other FX parameters - read on!EXP 1 and EXP 2OVIEWPRESETSWhen no additional Pedal is connected to the PEDAL 2 input, the on-board Pedal‘s “Toe Switch†will toggle between the control of Pedal Modes EXP 1 and EXP 2. The red EXP 1 and green EXP 2 LEDs illuminate to indicate the current Pedal Mode. (It is also possible to manually assign other functions to the Toe Switch - see “Using the EXP Pedal Toe Switch†on page 3•13.) Quote Link to comment Share on other sites More sharing options...
bull1030 Posted November 20, 2013 Author Share Posted November 20, 2013 Its looks that if after playing with it that onboard pedal is engaged and is exp2 that when you connect the EX1 it will take the assignment of exp1. All I did was unplug after turning on and plug it back in and seemed to correct itself. Quote Link to comment Share on other sites More sharing options...
