Sync (lockstep/mirror) 2 blocks - Settings..? Helix
livealoha50f
Playing Helix with true stereo amp config (for chorus).
Preset:
Amp 1 (detuned/pitch shift sharp 8% semitone) pan 100% left  - routed to FRFR speaker A
Amp 2 (detuned/pitch shift 8% semitone) pan 100%right - routed to FRFR speaker b
Works Great - Sounds Great...
Problem/Drag:
When I am tweaking/dialing in amps IR - effect blocks  - (because I have duplicate blocks chains  for left and right) I have to set amp A - then switch to amp B and set it...
I am looking for a way to lock-step/link  2 blocks.
 So that when I change the left amp block/chain - it mirrors the changes to the right amp block/chain...
Does anyone know how to do this... or care?  Has it been requested before?
Thanks...
Preset:
Problem/Drag:
Thanks...
Best you can do (assuming that you're working in HX Edit, not sure if the following is possible on the unit itself) is make your changes to one amp block, then right-click on the block itself, and copy/paste to the other. There's no way to have changes to one block automatically propagate to another... at least none that I'm aware of.
