Imaginario77 Posted February 8, 2019 Share Posted February 8, 2019 Hello! Anyone out there using HX Effects with Tech21 Trademark 60? I recently got the Hx fx. Wonderful gear. Full of great features. Used some pods before. Recently Pod Hd500x. But the Helix family seems to take it a step further. I got the HX Effects to try to make the most of it and its features. I use the loops, loop 1 to insert some pedals (mainly distortions) and loop 2 to make the 4 Cable Method (4CM). I have an expression pedal on input 1 and was trying to control my amp functions with the Ext Amp 2. So far I was able to change channel but I can't access any other functions on my amp. Can't control Boost/Reverb function neither Fx loop on/off. The only thing I can think about is that this happens because my Trademark amp usually uses a standard (mono, Tip/sleeve) cable to connect to its original footswitch and I think the Hx Fx is supposed to use a TRS jack cable. I've tried both with the same result. I can only switch between amp channels. While reading the manual trying to solve this I came across something that worried me because I really don't know what it means: "IMPORTANT! Connect EXT AMP 1/2 only to amplifiers that utilize "shortto-sleeve" footswitch inputs. Connecting to any other sort of input could cause permanent damage to both your amp and the HX Effects device! If you're not sure if your amp has short-to-sleeve inputs, contact the manufacturer." I don't know what "short-to-sleeve" means... and if this amp applies or not. Could this be the problem? Am I in risk of damaging my gear? Anyone can think of something that might help me? Thank you so much! Keep rocking and rolling! Quote Link to comment Share on other sites More sharing options...
