StageScape monitor jack is "reversed".
Here's an annoying one.
Monitor jack C seems to be "reversed", meaning, if nothing is plugged into it, it's a green circle and a monitor is placed on the stage (e.g. when creating a new scene or starting up the board).
If I plug a monitor into it, the monitor is removed and the jack indicator is cleared.
The board seems to have it backwards. Naturally, I want the monitor cleared when I unplug it, and I don't want the jack indicated as active and a monitor auto-placed on the stage when I have nothing plugged into it.
This also has the result of making monitor out C useless.
This isn't a sudden occurrence, I just always assumed a monitor was placed on the stage for some reason, and I would just remove it after I started the board up. Annoying but never got in the way.
Now however I need all four monitor outputs, and after working with "C", I found this out.
I tried a factory reset (this board resets to version 1.20), nothing.
Is there a way to fix this on my own or do I just forego Monitor C and otherwise eventually send it in for service?
Never heard of this one before. Seems like a faulty sensor on the Mon C jack. Probably needs servicing.
You might get some some further info on what's going on by fiddling with the I/O reassignment feature described on page 2-5 of the M20d Advanced Guide (Rev D). But I don't think that will lead to a fix.
  • 10 months later...
