rdomain Posted March 29, 2019 Share Posted March 29, 2019 Does the HX Effects channel switching feature work with the Ruby Riot I? I've had a look around and couldn't find an answer. I bought the HX Effects to change channels on my Fender amp but it doesn't work with that unfortunately so I want to avoid the same disappointment if I buy a new amp. Any info would be awesome or even if there's a master list of amps that actually work with the HX Effects. Cheers! Quote Link to comment Share on other sites More sharing options...
C4TH Posted March 31, 2019 Share Posted March 31, 2019 Hi, I had a similar problem with my Blackstar HT40, but sussed it out after watching this video - And you may already know this, but make sure you use the right cable, i.e TRS, TS, etc. Hope this helps. Quote Link to comment Share on other sites More sharing options...
rdomain Posted March 31, 2019 Author Share Posted March 31, 2019 Thanks for the vid but I reckon I watched that one a while back when I first got my HX Effects. The Fender amp I have is one of those amps that definitely don't work with the HXE unfortunately. And yep, using the correct cable etc. Is there a master list of known amps that work with the HX Effects anyone? I'm currently shopping around for another amp and I'd really like it to be compatible. Quote Link to comment Share on other sites More sharing options...
