Ruby Riot and HX Effects channel switching?
rdomain
Does the HX Effects channel switching feature work with the Ruby Riot I?  I've had a look around and couldn't find an answer.  I bought the HX Effects to change channels on my Fender amp but it doesn't work with that unfortunately so I want to avoid the same disappointment if I buy a new amp.
Any info would be awesome or even if there's a master list of amps that actually work with the HX Effects.
Cheers!
Thanks for the vid but I reckon I watched that one a while back when I first got my HX Effects.  The Fender amp I have is one of those amps that definitely don't work with the HXE unfortunately.  And yep, using the correct cable etc.
Is there a master list of known amps that work with the HX Effects anyone?  I'm currently shopping around for another amp and I'd really like it to be compatible.
