Blending two amps - boost quiet one or cut loud one?
user-2598552
Hi all. When blending amps in parallel in a mono patch, is it best to boost the quieter amp or cut the loud one?
There are 2 IR's in the patch also in parallel. Is it best to boost/cut in the merge block or should I raise/lower the IR's which are always set to -18db? (and why are they always -18db and does it matter?)
What about using a gain block to boost the US small tweed so it's the same volume as the tweed blues when blended?
