Sign in to follow this
puneetxtaneja
DT25 - Direct Out Cab Simulation
Does anyone know what kind of cab/mic/mic placement simulation is included in the DT25 Direct Out? Is there any way to turn off the cab simulation and use and external cab loader?
If you have the 2.0 firmware loaded on the DT25, you can select "None" as the cab by sending the MIDI CC message associated with that.
https://line6.com/data/6/0a06434df0f650914b2056015/application/pdf/DT Amplifier MIDI Implementation Guide - English ( Rev A ).pdf
The other thing you could do is use Low Volume Mode and use take the output from the DT25's effects send into your cab loader. In Low Volume Mode, there power amp modeling applied to the preamp section. If you do this, though, you're not getting any actual contribution from the DT-25's power section.
