schilcur Posted April 15, 2019 Share Posted April 15, 2019 I did a quick search of the forum and didn't find any posts matching up with my problem. During a couple recent gigs I ran into an issue where my sound was intermittently dropping out. Did a lot of changing on the fly to solve the issue but I'm still a little frustrated as to why it's happening. Main rig consists of a few pedals in addition to the FBV3. I run into a wah pedal, talk box, distortion pedal, and tuner, then to the amp. Use the head/amp as a personal monitor, depending on the sound level I need. I have experienced the dropout with both the head only, and the head running mono into the Line 6 cabinet. Once the issue started occurring, I took the foot pedals out of the signal path and ran instrument cable straight to the amp.....still encountered the problem. Problem wasn't patch-specific...it happened with a couple different patches Problem cropped up later in the second set After still experiencing the problem with the instrument cable, I switched to wireless, and that seemed to "cure" it. I have a voltage meter on the end of our multi-tap power cable to make sure we're getting the right voltage.....never dropped below 123V. I was wondering if anyone else has experienced this issue. Love the amp.....I play mostly covers and need a range of sounds, and the Line 6 fills that need nicely. I would really like to get to the root of this issue. Doesn't happen all the time, but really annoying when it does. Quote Link to comment Share on other sites More sharing options...
thorneven Posted April 22, 2019 Share Posted April 22, 2019 You say "never dropped below 123V." But a power fluctuation above 123V would cause the symptoms you cite. Are other devices hooked up to that power cable also experiencing these losses? Quote Link to comment Share on other sites More sharing options...
