Mute The Main Out Only
Hey all.
So my band has been using the Stagescape for some time now for live gigs, what I would like to do after a soundcheck is to mute the main outs to the PA, but leave the monitors active. We don't use any backline just a Helix and a Axe FXII straight into the desk, so it would be nice to still have the monitors active without anything coming out of the PA.
Just wondering if this is achievable? Not really sure why there is not a mute icon next to the onscreen slider.
Cheers all :)
  • 8 months later...
I came to the forum looking for the answer to this exact question. I thought I was being dumb in not being able to find something which must *obviously* exist in kit so beautifully designed...
Option 1: Powering down speakers is extremely clumsy and awkward, to achieve something so simple. Option 2: Disconnecting main outs doesn't work when my speakers are all connected via L6link
So, @steverubble did your idea of creating said Scene do the job? Like you I don't use them (yet) and am looking forward to seeing up my pa too test your idea. Thanks!
  • 6 years later...
If you want to mute only the main output while keeping the other outputs active, check whether your device supports assigning a separate mute function or using an external mute switch on the main output path. The exact setup depends on which Line 6 unit you're using, so the model and current output routing would help narrow down the best solution.
