Silenoz Posted April 25, 2019 Share Posted April 25, 2019 Hi, So after receiving my third (!) Helix LT unit after the previous two had broken expansion pedals, the preset joystick is now broken. As I understand you should be able to push it down like the action joystick.. I was able to use the preset joystick about two times to change setlists, before it just was stuck to the unit itself and I am no longer able to press it down. I am able to turn it to change presets on the same setlist. My question is, is there another way of changing setlists on the unit without using the preset button (or on a computer)? I do not live in a city with any dealers which sells Line 6 products and neither are there any Line 6 service shops nearby, so I have to send it. The first time I sent a broken unit it took two months before I got a new one and the second time it took one month. So I really dont want to send it in again. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 26, 2019 Share Posted April 26, 2019 You can use HX Edit to change setlists, I don't know of another way to change setlists from the Helix if the 'Preset' joystick is broken other then if there is a MIDI command. I suppose you could switch that way. Much as it may pain you to have to wait for a new one again I would send it in for repair/replacement while you can. You don't want to have to live with a broken joystick. Maybe after hearing your tale of woe the dealer or Line6 can expedite the return process this time around. Quote Link to comment Share on other sites More sharing options...
Silenoz Posted April 26, 2019 Author Share Posted April 26, 2019 Yeah I have been using HX edit to change setlists, but dont want to have to have my Mac with me all the time. I have contacted Line 6 and they are working on a solution. Hopefully they figure out something good. Quote Link to comment Share on other sites More sharing options...
Savl Posted October 30, 2019 Share Posted October 30, 2019 I had a same problem with the "presets" knob. It was terrifide! What a did: I put off the plastic cover from button. And it's work! I put inside small piece of plastic so that it dosen't fell so deep. Men! it's can be just plastic cover)) Quote Link to comment Share on other sites More sharing options...
