Can't see recordings on a Mac
Hi, I have successfully recorded from my m20d to an SD card. I can play and mix the files on the mixer. When I put the (fat 32 formatted) card in my Mac, I can not see any of the files. They are still there, just not visible. This has worked properly in the past and I'm not aware that anything has changed since it did.
Any thoughts?  Thnx!
  • 4 weeks later...
something changed on your mac...
Launch Terminal.
Type "defaults write com.apple.finder AppleShowAllFiles YES" in Terminal and press "Return."
Hold 'Alt' right click on the Finder icon in the Taskbar, click 'Relaunch'.
Then do you see the files?
If you want to undo this, replace YES with NO in the above sequence and you're back to normal.
If you saw them before and don't see them now, it's something mac-based.
