Sign in to follow this
marshyj
Two heads with 412VS cab?
Hi All,
I have a 412VS that I use with my Vetta II head, but i recently purchased an Orange Jim Root Terror which sounds awesome through it. My only problem is, it only has one channel. So my question is: Is it possible to run my Vetta II through two of the speakers for clean tone and my Orange Jim Root Terror through the other two for the dirty tone? I know the cab is stereo so I'm assuming that means top two speakers are separate from the bottom two...
If so, any ideas how?
Thanks for your help!
Yes, it's pretty straightforward. Just set the switch on the back of the cab to stereo mode, and hook each amp up. You just have to make sure you're using an 8 Ohm output from the Orange amp and the mono output from the Vetta (output impedance isn't really an issue with the Vetta as it has a solid state power amp).
