Bboy19 Posted May 11, 2019 Share Posted May 11, 2019 Hi, I have a few questions. I tried searching but came up empty. 1. Is there a list of the presets and who they emulate? I can figure out some, but have no idea of the others. 2. I want to send my signal out to two other amps. I have the regular Outputs taken up with a stereo setup. Can I use the effects loop Send to the input of the other two amps? What would the best way to do this? 3. Can I use the effects loop return as input. Save cable swapping from various instrument? What a great unit! That's all for now. Thank You . Quote Link to comment Share on other sites More sharing options...
amsdenj Posted May 12, 2019 Share Posted May 12, 2019 1. There’s no specific list of presets that emulate artists or songs, but you may search Custom Tone and find things to try. To figure out tones, try searching for the band/song on YouTube, or go see them live and see what guitars and amps they are using. Then see if you can figure out what pickup they are using. This will provide a pretty good starting point. Adjust saturation, tone, effects from there. 2. Helix has three outputs you can use: XLR L/R, 1/4” L/R, and Headphone. If that’s not sufficient, or if you need more control about where the outputs are in the signal chain, you can use Send blocks anywhere you need them. 3. Yes, and these might match the impedance of your instrument better than the Aux input. On my acoustic gigs, I have a Strat, acoustic guitar and mandolin plugged in all the time. Start in the guitar input (needs high-Z), mandolin in Aux, and acoustic guitar with active pickup into Return 3. Different patches determine which input is active. Quote Link to comment Share on other sites More sharing options...
Bboy19 Posted May 12, 2019 Author Share Posted May 12, 2019 Hi Amsdenj, thanks for the information. I was hoping that the sends/returns could be used. Thank You Quote Link to comment Share on other sites More sharing options...
