HX Stomp - Scroll Presets in Bypass Mode?
Tp13
Hello -
Does anyone know if there is a way to scroll presets while in bypass mode?  I also have an H9 and find it very helpful at live shows to be able to navigate to a desired preset before engaging the pedal.
Any input appreciated!
Not really... You can put the Stomp in Bypass All mode, but as soon as you hit any of the switches, it will go back into the preset. The Stomp's architecture is a little different than the H9 in the fact the H9 is running one algorithm per preset, and you're just bypass that algorithm. With the Stomp, there's six block in a preset, and you can bypass any or all of them however you like. If you wanted save the preset (or a snapshot) with everything bypassed, you could most certainly do that.
The other thing is you can go into Preset Mode, and you scroll through the banks, the preset won't be active until you stomp on the switch for that preset. So you can start scrolling ahead of time and then just hit the switch for the preset when you want to activate it.
