allyboo22
POD XT Advice
Hey guys,
Looking for some advice regarding the Line Pod XT!! I have been using the Line 6 Pod XT for recording at home and got loads of presets pm Pod Farm, I am looking to use them in a live environment but as there are certain amps and stuff I have on pod farm which arent't on the XT I can't use them. Is there anyway of adding amps to the XT in the same way you would add tones?? Any advice at all would be greatly appreciated!! ;) Thanks in advance for for any help provided!! ;)
Even though this is the PODHD forum the answer to your question is still no.  Amps are programmed in by Line6 as updates or addons.  The POD XT is not receiving anymore updates or addons.
Thanks for the reply, much appreciated. Been seeing that the Pod XT has been pretty much discontinued which is a shame because it is a good bit of gear and been pretty reliable. Guess I will need to look at getting an upgrade to a Helix or something in the near future. Thanks again for the reply. ;) Ally
5 hours ago, hurghanico said:
If you buy and install the Triple Pack Bundle Model Pack in your XT you will have all the models included in POD Farm:
https://shop.line6.com/software/model-packs/triple-pack-bundle.html
if you don't need all of them, you can buy the separate model packs for your device:
https://shop.line6.com/software/model-packs/?cat=23
other solution:
sell the XT and buy the X3 which has all POD Farm models already included
Hi there,
Thank you so much for the reply. I'll look into getting the triple bundle pack. When I do have it, how do I transfer the amp models from the pod farm to the xt?? Thanks again for your help and advice!!
1 hour ago, hurghanico said:
As soon as you install the triple bundle pack in your device (probably you will have to use the License Manager program to do it) all the same models included in POD Farm 2.5 Platinum will be already in place in your POD, no need to transfer.
The only things that need to be added/saved in the POD are the presets/patches which use those models, so you can use the POD alone without the computer.
That's perfect buddy, thanks for the advice and info, I'll get on it  and get the triple pack ordered!! Thanks again, you're a great help!! Al
