ClausHIllerup Posted May 23, 2019 Share Posted May 23, 2019 Hi all. I use Jason Sadites Helix patch set-up, with EQ and compression blocks in the end. I recently joined a band again, and we are having our first gig next saturday, at a 50 years birthday. We will not have a sound guy at this job, and this is why I turn to you for some advice. We are a 5 piece rockband, 2 guitars, bass & drums. I play all the lead parts, the other guitarist is my Malcolm Young :-) I play through a Tech21 Power Engine, with a full range Beyma speaker,- the other guitarist tend to have a somewhat dark distorted sound in his Rhythm parts. I primarily use PRS HB and the other guy uses P90s. At our rehearsals I have experimented with setting the low cut on my solo patches as high as 180 HZ, as well as other things to cut through the mix. I really think this works well in the rehearsal room. From readings, I guess that a low-cut at 180 HZ is quit extreme (I got the idea from a guy mixing guitars in a studio)… So my question is: Is there something in this approach I should be aware of, when playing live in bigger locations? I hope you could find the time to give me a hint or advice. Quote Link to comment Share on other sites More sharing options...
