kimkyongnam Posted June 9, 2019 Share Posted June 9, 2019 and broke text too This is what happened after the firmmware update attempt. . i am really sad.. how i fix this ? i was try factory reset too but dosent work.. i live in korea. please help me Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 10, 2019 Share Posted June 10, 2019 18 hours ago, kimkyongnam said: and broke text too This is what happened after the firmmware update attempt. . i am really sad.. how i fix this ? i was try factory reset too but dosent work.. i live in korea. please help me Hi, You say that you tried to do the factory reset, but there are others that may work. Try “Safe Boot” first then re-install the Firmware. Maybe you did not update the “driver” first! Check out this link to see if you can find a fix for your Helix LT It looks like a similar problem to this one posted here: https://line6.com/support/topic/46767-helix-lt-not-working-after-update/?tab=comments#comment-297380 I hope this helps you. 1 Quote Link to comment Share on other sites More sharing options...
kimkyongnam Posted June 10, 2019 Author Share Posted June 10, 2019 11 minutes ago, datacommando said: Hi, You say that you tried to do the factory reset, but there are others that may work. Try “Safe Boot” first then re-install the Firmware. Maybe you did not update the “driver” first! Check out this link to see if you can find a fix for your Helix LT It looks like a similar problem to this one posted here: https://line6.com/support/topic/46767-helix-lt-not-working-after-update/?tab=comments#comment-297380 I hope this helps you. I really appreciate your help !! I fixed my helix lt ㅎ I try drive update And using another laptop Thank you! 2 1 Quote Link to comment Share on other sites More sharing options...
