HX Stomp Output Level through USB
maximilianfaith
Apologies if this has already been covered...
I'm recording using the HX Stomp as my interface into Ableton.
The patch Im using is Guitar > Placater + 4x12 (master 5, channel volume 5) > output.
Im having to add as much as +16db to the output block to get some appropriate recording levels and I'm not even close to clipping in ableton.
What am I doing wrong? :)
Thanks in advance!
Here's a link to a lengthy article on the subject:
https://www.soundonsound.com/techniques/gain-staging-your-daw-software
Here's a relevant excerpt:
"If you take the sound with the highest peak levels and set it so that it peaks at between -12 and -18dBFS, you shouldn't run into problems with plug-ins or summing on the mix bus. If these figures look different to those I discussed in relation to analogue gear, remember that the meters are different, and you're actually leaving about the same 20dB headroom. I wouldn't expect to see peaks on the channel meters reading more than -8 to -10dBFS (and lower is often better). The highest level track in your mix will vary, but in rock and pop it's usually the kick or snare. Set a rough balance of your other tracks in relation to that track and you should be good to go."
