Tahax92 Posted June 18, 2019 Share Posted June 18, 2019 Hi everyone, I recently ordered my first Helix LT after 12 years with the Vox tonelab LE (which died last month), so I was using it in front of my Mesa Electra dyne using only the clean channel, so my question is what's the best way to use the helix with my setting ? I saw the FX return way, the 4CM way, the plug straight in the front way, which one to choose ? I love the clean channel of my amp but I want to use as much as possible the helix :) The helix is on it's way so I'm speaking to those who has or had a similar settings ! Another question, I have a Mesa high wire dual buffer booster and I use as a volume boost (end of the chain), so will it works as a volume boost if I plug it into one of the Helix's FX loops ? Thks for the replies guys, I'm eager to play with it when it'll be there ! Cheers from Tahiti ! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 18, 2019 Share Posted June 18, 2019 Use 4cm. put your front of amp effects first, then a Helix pre-amp, then an FX Loop Block, then your post amp effects. Set it up to toggle the Helix pre-amp and FX Loop Block - when the FX Loop is ON, the Helix pre-amp is off and you're going through your amp's pre. When the Loop is OFF the Helix pre-amp is ON and you're using the Helix pre-amp through your amp's power section. Best of both worlds! Quote Link to comment Share on other sites More sharing options...
Tahax92 Posted June 19, 2019 Author Share Posted June 19, 2019 Thks for the reply, I'll try that first when i'll receive it for sure :) Could I use more than one preamp from the helix ? Like a ac30 style for crunch, a cali iV for rythm and a litigtaor for lead ? Would snapshots work for that ? Cheers ! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 19, 2019 Share Posted June 19, 2019 I've never used more than 3. You can usually get 2 per path, but amps are very DSP intensive, so you start running out of resources for other things. Experiment. Have Fun! Yes, you can use snapshots to change amps. I usually use 2 amps. A clean amp and one that sounds good with a crunch and a heavy sound. Then I use snapshots to change the amp settings to get as many variations as those amps + OD/Distortion boxes can give me. Since you're going 4cm, you can also work your real pre-amp and amp channels in. VERY flexible arrangement. Quote Link to comment Share on other sites More sharing options...
